sehneml
Jun 12, 2020Aspirant
4G+ Netgear mr1100 carrier agregation
How long will we be without carrier aggregation on the mr1100? Will netgear not release a firmware update to resolve this issue?
My router does not work with any aggregation, even though coverage is available
- mxaherAspirantYou have to check first if your provider is blocking carrier aggregation on routers.
Use your mobile phone to check bands your phone connected to.- sehnemlAspirant
my device has the latest update, and my operator with the cell phone works with AC in the 3 + 28 bands, but the netgear router cannot do this aggregation
- Ksa3344ApprenticeThere is aggregation and they added more with the last two updates , and hope they add more also .
Check in your mobile and see if you have it maybe your carrier tower does not support it.
