pollardd
Aug 05, 2019Aspirant
4G Signal Bars drop from 5 to 2 after 30 minutes and stays that way
Hi Guys, I have a LB2120 and it is working fairly well. I'm in a regional area and have it connected to an external 4G antenna. It's permanently connected to 4G. It is not used in fail over mode. ...
Blanca_O
Aug 26, 2019NETGEAR Employee Retired
Hi David,
You mentioned that LB2120 is connected to an external 4G antenna. Have you tried another external antenna?
Blanca
Community Team
- pollarddAug 26, 2019Aspirant
Hi Blanca,
That's a good idea unfortunately I only have one antenna.
When I say it is external it's bolted to the outside of my house on a mast.
It's a good quality directional antenna worth a couple of hundred dollars so I'd be very surprised if the antenna could cause this problem. It used to work consistently on my previous modem.
I actually have a second LB2120 for use at a different site and I thought I’d try that one before I deploy it. The second device starts on 5 bars for about 30 seconds then drops back to 2.
I have done some more speed tests on both devices, while on 2 signal bars and the speed is OK. Consistantly it obtains a Ping 31ms Download ~45Mbps Upload ~ 10Mbps.
I think we will have to leave this as an "anomaly". I was hoping there was some power saving setting I could change to keep it at 5 bars but it seems I'm dreaming :)Thanks for your assistance.
David
- psynpaseFeb 15, 2020Aspirant
HI,
Only recently joined the community with a move from Huawei to a Netgear LB2120.
I also recently installed a MIMO pair of external antenna. With the Huawei I found that I had the same problem as you ( but typically after only 5 minutes). The Huawei has a slightly more sensitive rf front end than the Netgear, but in this case it did me no favours. The service provider would note that I had good signal strength and switch me to the high band, with major consequences :- my download/upload rate dropped from 80/20 Meg to 30/0.4 Meg.
The move to a Netgear LB2120 gives me 2dB less, just enough to avoid the telco shifting band! (And also provides me with Band 28 fallback)
Of course this may not be your problem, but check to see what your telcos policy is And check the modem status; you will see the band you are currently on near the bottom of the screen
- pollarddFeb 16, 2020Aspirant
Hi Psynapse,
My modem is still behaving much the same as when I originally posted.I can't see the band that it is currently connected with. I have my device in bridge mode as I have a Cisco router behind it and all the routing happens there. The LB2120 screens are actually really bland in bridge mode. I have an icon with 2/5 signal bars and it usually says 3G these days. I'd hold out no hope of ringing Telstra and asking them about this stuff and actually getting any reasonable response. Just for fun I did another speed test and Ping is 50ms Download is 6.0Mbps Upload is 1.24. This meets my needs so I just put up with it.
