jimbtx
Dec 14, 2019Aspirant
4glte 1120 wireless
when using eithernet cable, is wireless not available to connect my Ipad? When I connect to "Amped wireless extender REC22A", the connection shows "not secure"?
Blanca_O
Dec 19, 2019NETGEAR Employee Retired
Hi jimbtx
Welcome to NETGEAR Community!
LB1120 does not have a WiFi function. Can you please describe your network setup? Do you Internet connection wired to the LB1120?
Blanca
Community Team
- jimbtxDec 19, 2019Aspirant
1120 is connected with eithernet cable to Dell Desk top. When trying to use IPad that need to be on wifi to work with apple care, It first saw my desktop as "available " wifi source. then later it does not show up?
When I conect the Netgear to a router it works ,but the connection shows as " not private/secure.
On a side note I can not see my original post here in community?
Jimbtx
