sinan60
Aug 17, 2021Aspirant
4GX Advanced III (Netgear AirCard 810S) not opening
Hi I have a problem with my 4GX Advanced III (Netgear AirCard 810S), when I push the power bottom it shows Telestar and 4XG and then go to black screen with "Shutting down" , it stay for long time ...
sinan60
Aug 19, 2021Aspirant
Hi
I did all but unfortunatly same, the screen not opening
AyeAyeAye
Aug 19, 2021Apprentice
Definitely try another battery if you can borrow one.
My old dad worked on electronics and if I know one thing never trust a software/OS battery gauge over testing the battery & voltage reading itself.
What does it display plugged into the mains with the battery out ? The same ?
- sinan60Aug 19, 2021Aspirant
Thanks, I will .
- AyeAyeAyeAug 19, 2021Apprentice
Was editing as you replied^
what does the screen say on mains only with no battery ? Still "shutting down" ?
If the battery is caput/shorting it can send wrong readings to the OS.
Can you connect it via usb to computer with no battery ?
Yes I can
