sinan60
Aug 17, 2021Aspirant
4GX Advanced III (Netgear AirCard 810S) not opening
Hi I have a problem with my 4GX Advanced III (Netgear AirCard 810S), when I push the power bottom it shows Telestar and 4XG and then go to black screen with "Shutting down" , it stay for long time ...
AyeAyeAye
Aug 27, 2021Apprentice
Is this with or without the battery ? I assume you tried both ?
sinan60
Aug 29, 2021Aspirant
Hi
Yes you are correct with both.
just 3 days ago suddenly it opened , so what I did, I update the software and after that I reset it.
I assumed that it will work so I shut it down.
The next day I tried to open it again but unfortunately like before it show " Shutting down" and the screen is not opening.
when I connect the Cable to my Laptop it shows he setup
I am wondering, is it Hardware or Software problem I did not find that.
Firmware Firmware Version: NTG9X40C_11.14.08.40
Firmware Build Date: 2019/12/01
Web App Version: AC810S-1TLAUS_03.03.102.25
Bootloader Version: NTG9X40C_11.14.08.40
Hardware Version: 1.0 TRU-Install:
PHS_TELSTRA_B4059
Shuttin Down
