duvoe
Mar 05, 2022Follower
5100 wrong battery installed message
5100 wrong battery installed message when powering on.
michaelkenward
Mar 05, 2022Guru - Experienced User
duvoe wrote:
5100
Message on what?
Netgear's Nighthawk WiFi Routers – the stuff covered in this section – don't have batteries.
Blanca_O
Mar 10, 2022NETGEAR Employee Retired
Hi duvoe
Are you using the battery that came with the unit?
Please power on the device without the battery then check if you'll still get the error message.
Have you tried doing a factory reset? If not, please do so and provide us an update.
Kindly provide the device SKU (e.g. MR2100-xxxx) and firmware version.
Blanca
Community Team
