NeilCroft91
Apr 21, 2020Tutor
5ghz to 2.4ghz
CAN SOMEONE PLEASE HELP ME BEFORE I GO CRAZY PLEASE
Apr 21, 2020Guru - Experienced User
help you what?
you didn't put any info like:
1.device you're using
2. what help you need
3. firmware you're on
4. what you've tried.
and to the left of the "A" key is a caps lock key. please use.
- NeilCroft91Apr 21, 2020TutorSorry, i have a netgear night hawk m1, i accidentally switched from 2.4ghz ti 5ghz on my mobile app, since then my mobile phone or laptop won't find my hot-spot, and i cannot connect to my mobile app without being connected to the hot-spot itself, is there any way to change it back without the app?
- Blanca_OApr 22, 2020NETGEAR Employee Retired
Related thread:
