DM999's avatar
DM999
6000451 Antenna reduces my Speed.
I have the MR6500 Modem. I also bought the Mesh System, AX1800 to improve Wifi coverage in my home. Seems to work well. Getting about 25MB download and 4-5MB upload speeds using speedtest in the Mesh System app.
I thought I might be able to improve this by buying an antenna. Bought the 6000451 antenna from Amazon brand new. After connecting, my speeds drop tp 9.35 MB download and >1 upload.
Anybody have any ideas?  Using the device in the same location, near a window where I get the best reception for both situations. The pins on the TS-9 connectors are good (not bent) so I'm sure I'm getting them connected.
Would appreciate any input.
DM
  • Moist likely an issue with MIMO 4x4 (Quad internal antenna array) vs MIMO 2x2 (dual external antennas).  When using the internal antenna array, you're actually receiving more signals than when using the external antenna.  This will result in less throughput.  Assuming that you're using a 2x2 antenna that connects to both of the TS-9 inputs on the bottom of the MR6500.  You should only use the external antenna connectors if you have very weak signal and need the additional boost.  Otherwise you will be compromising the device's ability to pull in signals.
    • DM999's avatar
      DM999
      Thanks for the reply - so are you saying that the flat antenna that I have (6000451) has 4 internal pickups inside it, and I'm likely getting conflicting signals that could be sitting on the signal I'm trying to pull in? That could certainly explain it. WHen I bought the antenna, i was set up in one are of the house - but found a much better location elsewhere. Thought this antenna would simply improve the signal reception, but I hear what you are saying. It absolutely behaves that way. Wonder if I should keep the antenna for times when I travel and have worse signal...
      • DM999's avatar
        DM999
        Actually just saw that the MIMO product you were talking about appears to have 4 cable leads - mine is a NetGear 6000451, with only two leads.
