Caracatus
Feb 05, 2017Follower
782s Aircard and 760s Wireless Aircard Hub
Am currently using, and appreciate, the 760s Aircard, and the Sierra Wireless Aircard Hub. When I', on the road, the 760s gives reasonable 4G coverage, but it does not support 700MHz, but my home was only covered by 3G, until recently.
So, since my local 3G tower has finally been upgraded to 700MHz LTE, I am looking at changing over to the 782s.
The size, shape and location of both the USB port, and double antennae ports appear to be the same. Can anyone advise if the 782s will fit my existing Aircard Hub? I don't want to loose the connectivity the hbu provides, and will probably put up with 3G at home, if not.
Thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello caracatus
the AC782S will not work with the old Sierra Wireless AirCard Hub. AC782s is however compatible with DC113A and DC112A cradles
DarrenM
