mathieu75000
Feb 12, 2020Follower
938 devices connected to my Netgear Router suddently
Hello, I am having an issue with my router with some 939 devices connected that are not mine... I m affraid i m being hacked somehow. That number is getting higher and higher while i writte thi...
Feb 12, 2020Guru - Experienced User
What router are you using?
Firmware on it?
What modem are you using?
What happens after a reboot?
Have you tried a factory reset and reinstall? Change the login password when you redo setup.
