ausgumbie
Nov 07, 2017Aspirant
A repeated query about AC790S and KRACK
I am going to attempt to resubmit a question I had submitted on 17th October last, but which mysteriously disappeared. The thread was found on another url. I won't bother including this as it isn't v...
- Nov 16, 2017
Many Thanks
ausgumbie
JamesGL
Nov 16, 2017NETGEAR Employee Retired
Hi ausgumbie,
Device does not support bridging that is why it is not on the list. If the device does not have bridging option then it is not affected.
ausgumbie
Nov 16, 2017Aspirant
Hi James
Made a bit of an error allocating "Solution" mark. Gave it to my "Thank You" note. Anyone able to change it to your post of the 15th which is the post I meant to mark?
Many thanks
ausgumbie
