antonio993's avatar
antonio993
A6210 wifi adapter issue
I use the 16210 wifi adapter to help with wifi speeds but when I restarted my PC it was suddenly not getting any internet the only solution I have been able to get is waiting it out but how do I manually fix this?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    It is down to Windows to manage the A6210 and its wifi connection.
    If you also have a wired connection, Windows is likely to prefer that. You will have to tell it to connect to the wifi in Network and Internet settings. (That's Windows 11.)
    For more help with this device, try the appropriate section:
    WiFi Adapters - NETGEAR Communities
    Disclaimer: Just another user with time on their hands.
