misha_n
Feb 11, 2020Aspirant
AC1000 router won't connect to LB1121 modem
I purchased a LB1121 4G/LTE modem and would like to connect it to an AC1000 router and run WiFi through there. SIM card is activated and in the modem, both devices are connected, all lights are green...
misha_n
Feb 12, 2020Aspirant
Appreciate the help!
When I first connected the two, though, the modem was in bridge mode with routing and DHCP disabled. I've since reset the modem to factory settings and will try again disbaling the routing functions again, but I don't know if that's the only issue.
Feb 12, 2020Guru - Experienced User
Maybe passthrough isn't functioning properly. If it doesn't work, try putting the router in AP mode and seeing if that works.
