tjones99
Apr 08, 2020Aspirant
AC330U unlock not working
I contacted Rogers I provided the IMEI (copied and pasted from the Aircard Watcher and confirmed correct reading the back of the device) Rogers provided an unlock code. (note this is free and manda...
Blanca_O
Apr 19, 2020NETGEAR Employee Retired
Hi tjones99
Welcome to NETGEAR Community!
Please reset the device to factory settings then try the unlock code again.
Blanca
Community Team
tjones99
Apr 20, 2020Aspirant
Would if I could is probably the most accurate reply to your suggestion of resetting to factory defaults...
There is no reset procedure that I can find anywhere... and I have looked. I have searched Sierra Wireless and Netgear documents and manuals, I have looked at FCC documents. I have looked at user posted hig resolution images of the AC330U internals and there is no button of any form you can press to reset (contrary to many posts that talk about hard reset on the device). I can find no way in the included Rogers watcher program nor the Netgear Watcher program (Windows, haven't tried Mac).
So if you are aware of some way to accomplish this factory reset I am all ears...
