DanIAm
May 12, 2018Aspirant
AC785 One Click Firmware update doesn't work
I can't get the One Click Firmware update utility to work. It runs, says it's connecting, downloading firmware and flashing successfully, but the firmware doesn't actually get upgraded. I don't belie...
JasonN
May 15, 2018NETGEAR Employee Retired
Hi DantAm,
Can you please PM me with firmware // PRI # // Sku # // etc. to me.
What troubleshooting have you done?
Please provide your contact information.
Thank you. :]
- Jason N
- DanIAmMay 21, 2018AspirantSorry have been busy and have only just seen your messages. I'll dig the info out, but probably won't be able to respond until Friday.
- JasonNMay 21, 2018NETGEAR Employee Retired
Hi DanIAm,
Thanks for the response! That is fine. Just send the information to me as soon as you can and we'll move forward from there. :]
- Jason N
- DanIAmJun 05, 2018Aspirant
Hi,
I received an OTA firmware update which seems to have fixed the issue. Not sure if that was something you initiated, but it's working now, thank you!
Best Regards,
Dan.
