lteparanoia's avatar
lteparanoia
AC790S and AT entercnd password
You can connect to your AC790 at port 5510 over telnet to gain access to "AT shell" which responds to various AT commands, e.g. status or band selection. The same e.g. with AC810S. More advanced commands require entering password first, kinda to unlock them. It is "grouse" for AC810s. Does anybody know the password for AC790s? It is neither "grouse" or "whistler".
  • AC815s:
    AT!ENTERCND="fallow"
    Please try. Thank you.
  • Anonymous's avatar
    Anonymous
    Hi,
    For AC790-100EUS you should use AT-password "lavender". Please try it and let me know. If you have another version of the 790, please give me full model information.
    Thank you.
    • trodelphin's avatar
      trodelphin
      Initiate
      i have the 790s (Australian Telstra)
      and
      AT!ENTERCND="lavender" seems incorrect
      tried whistler, seymore, grouse, cypress and lavender
      any help appreciated :)
      • plus-sk's avatar
        plus-sk
        Apprentice
        Hi, please try:
        AT!ENTERCND="sunflower"
        It should works with Telstra version.
  • Can anyone help me find entercnd key for netgear AC815s from AT&T.
    • plus-sk's avatar
      plus-sk
      Apprentice
      AC815s:
      • spamcoll's avatar
        spamcoll
        Tutor
        Hello plus-sk,
        Please help me to find out entercnd command for Netgear 785S from Telus Canada.
        Thanks in advance.
