lteparanoia
Feb 05, 2017Aspirant
AC790S and AT entercnd password
You can connect to your AC790 at port 5510 over telnet to gain access to "AT shell" which responds to various AT commands, e.g. status or band selection. The same e.g. with AC810S. More advanced comm...
- Jul 14, 2017
AC815s:
AT!ENTERCND="fallow"
Please try. Thank you.
Dr_No_WaY
Aug 09, 2017Aspirant
Hello plus-sk,
Please help me to find out entercnd command for Netgear LB1111
Thanks in advance.
plus-sk
Aug 09, 2017Apprentice
I have no information about AT passwords for Telus AC785S and LB1111. It is necessary to research this devices first. Spamcoll, please check your private messages.
- nasar99Aug 09, 2017AspirantHi dear support,
I need command for AT!ENTERCND="grouse"
I had new firmware: NTG9X40C_11.14.08.24
Build date: 2017/06/09
Now doesn't work the command after this update , can I get net command password AT!ENTERCND="..?.." ? - Dr_No_WaYAug 11, 2017Aspirant
LB1111
at!entercnd="granville"
enjoy it :)
