lteparanoia
Feb 05, 2017Aspirant
AC790S and AT entercnd password
You can connect to your AC790 at port 5510 over telnet to gain access to "AT shell" which responds to various AT commands, e.g. status or band selection. The same e.g. with AC810S. More advanced comm...
- Jul 14, 2017
AC815s:
AT!ENTERCND="fallow"
Please try. Thank you.
plus-sk
Aug 09, 2017Apprentice
I have no information about AT passwords for Telus AC785S and LB1111. It is necessary to research this devices first. Spamcoll, please check your private messages.
nasar99
Aug 09, 2017Aspirant
Hi dear support,
I need command for AT!ENTERCND="grouse"
I had new firmware: NTG9X40C_11.14.08.24
Build date: 2017/06/09
Now doesn't work the command after this update , can I get net command password AT!ENTERCND="..?.." ?
