Alexgear
Apr 24, 2018Aspirant
[AC790S] Firmware update ERROR
Hi all,
I cannot update my AC790s' firmware, there is always a error message (see photos attached).
How can I update it?
Model: AirCard 790S
Firmware Version: NTG9X35C_01.03.28.0...
JoKiv
Jul 29, 2018Aspirant
This problem still exist. Locating firmware suitable to European models are restricted out from website.
Blanca_O
Jul 29, 2018NETGEAR Employee Retired
Hi JoKiv,
May I request for the following information:
- Where did you purchase the unit?
- What is the current firmware version installed?
- Do you have connectivity issue?
Make sure that you have excellent signal bars when you attempt to update the firmware.
Blanca
Community Team
- JoKivJul 30, 2018Aspirant
Hi,
I puchased device from Telia (ISP and mobile operator), Finland
Current version seems to be NTG9X35C_11.11.15.03
I don't have issues with connectivity.
I'll try again with better signal.
- Blanca_OAug 13, 2018NETGEAR Employee Retired
Hi JoKiv,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
- regchangOct 09, 2018Aspirant
Hi Support Team,
Can I still update the AC790S firmware online in this time? because it has been wrong, seems the update WEB site not find firmware file.
I puchased device from Telstra in 2016.
current firmware version: NTG9X35C_01.03.28.05Is there any way to help me solve this problem?
Thanks.
regchang
- BillMcQOct 15, 2018Aspirant
Hi,
I am having the same problem. I receive an ‘update error and will retry in 48 hours. message. My firmware is stuck on 9x35c 11.11.00.00
if anyone has solved this problem can they please post a solution
thanks in advance for any help
- net1gear1communDec 03, 2018Initiate
I'm here for the same problem - I have an AC790S from BigPond and I want to check and update the firmware. The Netgear site claims there is none available... is that true?
