frosch1993
Jul 24, 2018Guide
AC790S NAT Type Change on PS4
I would like to change the NAT type on my PS4 from 3 to 2 or 1. I already tried many things. Nothing worked out yet. I tried: DMZ, UPNP, port forwarding and IP-Passthrough mode.
I really need help! Any suggetions?
I figured out what the problem has been.
My provider couldn't get me an public IP adress. That's why it is not possible to change the nat type...
- thernusGuide
What kind of router are you using it in and what provider?
I get NAT Type 2 on my PS4 Pro with a 790s through either a Asus Router
or Gli Net AR300M in front of another router (Edge Router X with UPNP on and with DMZ enabled on the AR300M and IP passthrough on the 790s)
I use it as a mobile router whithout any further router. It's a mobile net provider...
- thernusGuide
Unfortunatly I havent tried it as a stand alone router, always with IP passthrough on connected to another router.
I would suggset a factory reset and try UPNP and DMZ again.
You dont happend to have two PS4's on the same network?
Another thing to note is most mobile providers dont supply a public
IP addres so you might be behind a CG-NAT (Carrier NAT) which does
block some things from working properly.
