frosch1993
Jul 24, 2018Guide
AC790S NAT Type Change on PS4
I would like to change the NAT type on my PS4 from 3 to 2 or 1. I already tried many things. Nothing worked out yet. I tried: DMZ, UPNP, port forwarding and IP-Passthrough mode.
I really need h...
- Sep 16, 2018
I figured out what the problem has been.
My provider couldn't get me an public IP adress. That's why it is not possible to change the nat type...
thernus
Jul 31, 2018Guide
Unfortunatly I havent tried it as a stand alone router, always with IP passthrough on connected to another router.
I would suggset a factory reset and try UPNP and DMZ again.
You dont happend to have two PS4's on the same network?
Another thing to note is most mobile providers dont supply a public
IP addres so you might be behind a CG-NAT (Carrier NAT) which does
block some things from working properly.
frosch1993
Aug 01, 2018Guide
Thanks for your suggestions!
Should I try UPNP and DMZ combined?
- thernusAug 04, 2018Guide
I would try just UPNP first then turn it off and then try DMZ, although they shouldnt conflict.
- frosch1993Sep 16, 2018Guide
