jspbills's avatar
jspbills
Follower
May 09, 2016
AC791L Mobile Hotspot Automatic Shutdown?
I'm hoping there is a way to set the AC791L to shut down entirely after ~1 hour of sleeping. I know there are variable SLEEP times on the verizon jetpack 4GLTE settings, but i sometimes forget to power it down by holding the power button and if i then leave it for a few days the battery is mostly drained. I'd like to set it to automatically power off completely when its had no connections for an hour or so. Is there a way to do this? Thanks!
Jason
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jspbills
    There is not a setting for this but it is a great suggestion for a feature.
    DarrenM
