PNGento's avatar
PNGento
Follower
Jul 01, 2019
AC791L offers dual band...what determines which band a device will connect to? Can this be forced?
My AC791L offers both 2.4 and 5GHz bands.  When set to dual bands, I only see ONE hotspot.  What determines which band any given device will connect to?  I am not too concerned about weak signal issues as the house is small, but most devices I have can use the faster 5GHz and that is what I would prefer they connect to, but find most end up on the 2.4 GHz band.  Is there a way to force to one or the other band?
Or can the two bands both show up like my Nighthawk does?
1 Reply
  • schumaku's avatar
    schumaku
    The wireless clients are deciding - based on signal level and quality evaluation.
    These WiFi Hotspot units are typically made to cover a very small range only.
