AncientDIYer
Jul 03, 2017Aspirant
AC791L won't tether unless I remove and reinstall the battery
I have tried every combination of powering it down and turning it on from the power switch as well as every combination of other settings. I checked and the firmware is up to date. Am I doing something wrong?
I bought the Netgear to replace a older Pantech because of online reviews, but the Pantech works every time.
- DarrenMSr. NETGEAR Moderator
Hello AncientDIYer
what happens does the PC not see the USB device until you remove the battery and put it back in?
DarrenM
- AncientDIYerAspirant
It appears to not be communicating with the PC. I see 3 to 4 bars of signal but do not see the up and down arrows indicating data transfer. I can power it down with the on / off button and turn it back on but it seems to need a cold boot from having the battery removed. Then it powers up in the same sequence as with the switch, but it establishes the connection.
Lately I've found that if I plug in the USB after turnng it on within a narrow window of the boot sequence, it will work.
I haven't tried it with wifi mode which I have found in the past to be even slower than the Verizon throttled snail's pace.
