hkl8324
Jan 16, 2022Aspirant
AC797 bricked.
Today I turned off the hotspot. But instead of turning off it REBOOT, it reboot like 3 times and display the I am using USB power with the battery inside. I feel that is weird and do a softret via th...
hkl8324
I mean i remove the battry during the softreset (i dont have any cable connecting during the softreset) , the hotspot reboot and keep turned off and i waited for 15 mins. So i think there is no response and i remove the battery.
And after that no matter what i do, (putting backing the battery or connect a cable the usb port trying to power the hotspot), it wont ever turn on again.
Margaret76
Jan 17, 2022Aspirant
is it fixed, or you still looking for solution? i do have same issue :/
