Genr
Mar 17, 2021Aspirant
AC800. New battery needed
I'm in Queensland Australia and need a new net gear w7b battery. For my AC800. for the life of me I cannot find any. I bought a no name battery today but it doesn't work. Any ideas please Thanks
- Mar 25, 2021I found one on eBay. It works. The only advertisement that says the battery will work in an AC 800 Optus
Domingo36
Genr wrote:I'm in Queensland Australia and need a new net gear w7b battery. For my AC800.
Thanks
I am also facing exact same issue. Is your issue resloved? any recommendation how to solve this issue.? Can any one please help?
michaelkenward
Mar 18, 2021Guru - Experienced User
You have posted your message in the section of this community given over to
Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
- GenrMar 25, 2021AspirantI found one on eBay. It works. The only advertisement that says the battery will work in an AC 800 Optus
