ShauningtoN
Jan 17, 2019Follower
AC800S 'Optus' - Cat 9 vs Cat 11?
Hi All,
Long time reader - first time poster!
Just had a query regarding the AC800s - Optus (Aus)
Background:
I have a new Optus tower in my area and I want to update my 4G device to ...
Jake_s1
Apr 22, 2019Aspirant
I don't have it yet. Are you saying it could be cat 11 depending on firmware?
The link to Optus is above in the original poster's questions
Kabe42
Jun 05, 2019Aspirant
I'm in the process of buying a second hand AC800S which is listed as being Cat 9. Following on from what the original poster's was asking, is it possible to upgrade the AC800S from Cat 9 to Cat11? If it can be done, what are the steps that need to be taken?
Many thanks in advance for any assistance.
- TeeJay74Jun 05, 2019Virtuoso
256-QAM support makes the difference between LTE Cat.9 and 11. Netgear engineer should be able to tell whether the software upgrade is possible.
