Tag_AU's avatar
Tag_AU
AC800S Replacement charging cable
This post is about the Optus AC800S (I choose the Telstra version from the dropdown as the Optus version wasn't listed).
Anyhow can anyone recommend a supplier to get a new AC charging cable as the one I have has been bent out of shape and chargign is very intermittant (why on earth did netgear make the connector so damn fiddly!). I don't even know the name of the weird endpoint format to do a decent internet search!
1 Reply
  • ok, just worked out all I need is a USB 3.0 Male A to Micro Type B cable. Pity that piece of info is not described in the bumf that is in the box.
