TeeJay74
Sep 30, 2016Virtuoso
AC810 users all around the world
What kind of actual upload speeds you have got compared to sim card subscription's nominal upload speed ?
- MirixTutor¡Hello! I want to buy a new LTE-Advanced router, and I'm undecided between these 2 models: Huawei e5186 and Netgear AC810. For me, the most important thing is signal stability. The AC810 has not QoS (only WMM, but not QoS) and the e5186 have QoS. It is important for the fluency of transmission, but I do not know if in these 2 models difference is very important .¿Do you have 2 models? ¿Which works best? In my home, now I have cat6 signal and I think cat9 soon. ¡Thank you!!!
- TeeJay74Virtuoso
I have both models. E5186 is an older model and it has some bugs with carrier aggregation. Choice is crystal clear. AC810 has better chipset inside, 3CA and 256-QAM(LTE Cat.11-model). Even the best device needs strong,high quality signal and services to show its best performance. New Aircard Smart Cradle will be soon released and according to manual, it has QoS. I have also pre-ordered this Smart Cradle. Netgear and Qualcomm, I believe in your products and highly recommend them to anyone who is interested in 4G LTE-A high performance.
- TeeJay74Virtuoso
if you have patience to await a little more, Netgear MR1100 is expected to launch Q1 / 2017.
https://www.youtube.com/watch?v=tPe0DU0SSX8
- MirixTutorThe AC810 device with a high performance cradle would be a very good solution for us. A set with more functionality than the e5186. The acual DC112c cradle (compatible with AC810S), has some problems, some bugs:
https://community.netgear.com/t5/AirCard-LTE-Hotspots-Gateways/DC112A-Firmware-problems/td-p/1108249
I'll be aware if any firmware update resolve the issues.
