dlbrum's avatar
dlbrum
ac815s (Unite Explore) connect to wired ethernet device ?
Thinking of going wireless only.   Are there adapters for non-pc devices that plug  into RJ45 ports and emulate wired connections from a mifi hotspot device connection ?
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi Dlbrum,
    I wanted to check in on you and see if you are able to provide me the answer to my question.
    Please let me know :]
    - Jason N
    • dlbrum's avatar
      dlbrum
      I decided to go with the Nighthawk.    I was trying to figure out how to extend an internal network to include wired internet devices like my little SAN box,   various PC boxes,  my home theater receiver,  tv and so on.   What I really wanted to find was a wireless downstream router for the hotspot that communicated wirelessly with the hotspot/router,   instead of using a wired connection.   So I looked around and found Arlo,  and those types of solution.    I think that for now,   I'll keep my slow DSL and play with the hotspot in preparation for arrival of 5G,  and maybe dump DSL at that point.
      • dlbrum's avatar
        dlbrum
        Of course,  in my reply,  I meant to say "orbi"   not "arlo"  as the device that would communicate router - router wirelessly.   Sigh.
        Early onset senility is not all it's cracked up to be.
        Thanks for your help !
  • JasonN's avatar
    JasonN
    Hi dlbrum,
    I am trying to understand what setup you are looking for. Can you be more detailed on what setup you're trying to pursue?
    Thank you :]
    - Jason N
