Slamfire
Mar 08, 2020Aspirant
Accessing Wired DSL Modem THROUGH LB2120
My wired connection has been flaky lately so I purchased the LB2120 for backup in the event the wired goes down. The LB2120 is connected between a Nighthawk router and my DSL modem. I just finish...
- Mar 11, 2020
In the event someone stumbles on this from Google or whatnot...
If your wired internet connection is down (but still physically connected); you will not be able to browse to that device (DSL/cable modem for example) from within your network THROUGH the LTE modem. As soon as my wired DSL connection was repaired and the LTE modem realized the "wire line" was good I was able to connect through the LB2120 to manage the DSL modem.
Slamfire
Mar 09, 2020Aspirant
Quick comment on the above - is this a known or planned function? For example if the wired connection is down does it attempt to reroute any and all traffic away from that (including IP address traffic trying to get to the DSL modem)?
I've not had the chance to try accessing it with the wired connection active and just realized maybe it would make a difference, shot in the dark but wasn't sure.
- SlamfireMar 11, 2020Aspirant
