yobyotan
Jan 29, 2020Aspirant
After ATT update to NTG9X50C_12.05.05.12 cannot connect to LTE network
Since the update to the latest ATT firmware, my unit has issues connecting to the LTE network. I have to restart it several times before it will connect. I usually use it tethered via USB-C but conne...
JohnPeng
Feb 05, 2020NETGEAR Expert
We expect that AT&T will release it asap after they approve it. Should be coming soon.
Thanks
yobyotan
Feb 11, 2020Aspirant
Sheesh...I wish you guys had stopped issuing firmware for this device. NTG9X50C_12.05.05.14 connects better but drops connections like crazy. I'm in the same location at a client and can look out my office window at an AT&T antenna farm on a building next door. The signal is so strong, it's vibrating my dental fillings. Yet the Nighthawk can't stay connected.
Is there no way to get back to whatever was before NTG9X50C_12.05.05.12?
- JohnPengFeb 11, 2020NETGEAR Expert
I am sorry to hear that you are still experiencing some connection issues. Could you please do a factory reset and check whether the issue can be fixed?
Thanks
