Gregg3821
Jul 18, 2016Follower
Air Card 815S I need a new AC Adapter HELP HELP HELP
I need to buy a new AC Adapter. Please help. I have lost the OEM one and no aftermarket charger will work. My air card is dead in the water without a new adapter. PLEASE HELP. I am willing to buy one...
DarrenM
Jul 20, 2016Sr. NETGEAR Moderator
Hello Gregg3821
You will want a power adapter that can output 5volt 1amp to charge the aircard you may want to check your cell phone charger plugs and see if they will work.
DarrenM
