GusRandall
May 18, 2015Aspirant
Aircard 340u Problem with Windows 8.1
I bought a brand new Windows 8.1 Laptop and Aircard 340u. I updated Windows 8.1 fully and then plugged in Aircard in. Supposedly, when you plug it in, Windows is supposed to recognize the device and ...
nhann
Aug 05, 2015NETGEAR Employee Retired
Hi Jlittle489 ,
Is your Aircard 340u updated to Firmware Version 01.13.12.13 ?
To update firmware on Windows 8, please follow : http://www.downloads.netgear.com/files/aircard/Win8%20Installation%20Instructions.pdf
If you are considering upgrading to Windows 10, here is more information on the device: http://kb.netgear.com/app/answers/detail/a_id/29490
Let us know how it works for you.
NhanN
- Jlittle489Aug 05, 2015Tutor
By plugging the device into another PC and running the AT&T AllAccess Software show that the firmware is "NTG9X15C_01.13.12.13 r18963 ntgrbc-"
- nhannAug 07, 2015NETGEAR Employee Retired
Hi Jlittle489,
Thanks for clarifying. There is a new version 01.13.12.14 now available that was released 8/7/2015.
Please follow the documentation to complete the upgrade.I hope to hear back from you.
NhanN
- Jlittle489Aug 07, 2015Tutor
I update the firmware again, but still the same issue. It is as if the device is not booting up correctly and reboots itself.
