GusRandall
May 18, 2015Aspirant
Aircard 340u Problem with Windows 8.1
I bought a brand new Windows 8.1 Laptop and Aircard 340u. I updated Windows 8.1 fully and then plugged in Aircard in. Supposedly, when you plug it in, Windows is supposed to recognize the device and ...
Jlittle489
Aug 05, 2015Tutor
By plugging the device into another PC and running the AT&T AllAccess Software show that the firmware is "NTG9X15C_01.13.12.13 r18963 ntgrbc-"
nhann
Aug 07, 2015NETGEAR Employee Retired
Hi Jlittle489,
Thanks for clarifying. There is a new version 01.13.12.14 now available that was released 8/7/2015.
Please follow the documentation to complete the upgrade.
I hope to hear back from you.
NhanN
- Jlittle489Aug 07, 2015Tutor
I update the firmware again, but still the same issue. It is as if the device is not booting up correctly and reboots itself.
- DarrenMAug 12, 2015Sr. NETGEAR Moderator
Hello Jlittle
Have you tried updating the drivers for your usb 3.0 ports I checked on Hps website looks like they just released some new usb drivers just a couple days ago. hope to hear your feedback.
DarrenM
- Jlittle489Aug 12, 2015Tutor
Will do! I'll install all the HP updates and report back the USB driver info etc. Thanks for the help!
