DJEvo
Feb 02, 2015Aspirant
AirCard 754S White Screen
Hello. I have an AirCard 754s, but when i was start device its only shows a white screen. A LED indicator blink one time. I think it's trouble with firmware, but how i can reinstall it?
- DJEvoAspirantI made it :). I use a nokia connection cable, and update tool restore last firmware. Topic can be closed :)
- Tom60NoviceI have a similar problem. If I start the aircard the blue LED flashes once and the LCD lights up. But nothing happens. Pushing the reset button does nothing. If I plug it into the laptop and run the firmware upgrade tool the program doesn't recognise a device is connected. I've installed the Windows drivers for the aircard.
It seems like the aircard doesn't want to boot up.
Any advice on how to fix this? - apac_seApprenticeSounds like an issue with the firmware. If your PC cannot recognize the device to run a firmware flash then I would recommend sending it back for repairs
- Tom60NoviceI suspect you might be right and unfortunately it's not the answer I wanted to hear. The aircard was purchased when I lived in another country.
- apac_seApprenticeYou should still be able to contact the returns team in that country and if lucky they can still organize to replace the unit.
- Hi I'm Andrew
New for this forum is such a grateful forum
Your' detail is working and thanks for share
this information
