pedrogold
Dec 06, 2014Novice
Aircard 762S logon problem
I've just bought a 762S and trying to logon without success. I'm told to use default Admin Password (webadmin) but it does not work.
What am I doing wrong?
- covillen1Apprenticepedrogold,
Here is a PDF for the air card if the instruction in this manual do not help or the content is wrong I would definitely contact Net Gear ASAP. There is no reason the default password and user name would not work unless you were giving the wrong information or the information has been changed.
http://www.downloads.netgear.com/files/aircard/AC762S/2400325%20AC762S%20(Generic-Europe)%20User%20Guide%20Rev1.pdf - apac_seApprenticeIf the default settings are working (i.e admin password) try a factory reset which will take the device back to factory defaults.
