sb003848
Jul 26, 2016Aspirant
AirCard 763S compatible router
Hello, I'm using my Netgear hotspot Aircard to connect my iPhone and AppleTV but the data transfer speed between the 2 devices is pretty slow so I'm wondering if there is a wireless router compat...
sb003848
Jul 28, 2016Aspirant
Thank you for the answer...
In this case, is it possible to connect my Aircard via USB cable to a wireless router ?
Thanks !
DarrenM
Jul 29, 2016Sr. NETGEAR Moderator
Hello sb003848
You may be able to find a router on the market that can do that but we do not have one.
DarrenM
