ebspars
Jul 27, 2016Follower
Aircard 763s USB tethered to Windows 10 not working
Just upgraded from W7 to W10 and can't connect via USB tethering. http://aircard.hotspot/ can not connect to Aircard. Device manager shows Sierra Wireless TRU-Install under Universal Serial Bus. Other computers can connect via wifi to Aircard.
Is there a way to have W10 connect to Aircard via USB tethering?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello ebspars
Since you upgraded from WIn 7 to WIn10 you may want to uninstall the drivers for the aircard and re install them also does your wireless provider have any software for your aircard device I would check on there website.
DarrenM
