RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
GlenRoberts
Nov 20, 2015Initiate
See my (GlenRoberts) message posted 11/20/2015.
cathyr
Nov 20, 2015Tutor
Great advice thank you.
I did a factory re-set and may have solved the problem that way, we'll see if the errors pop up again. If so I'll remove the battery and SIM card as you suggested. Glad you are up and running again.
