RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
Rcmaling
Nov 29, 2015Tutor
I tried removing the sim, battery and factory reset...nothing worked. Also I tried using it without a battery installed but it would not start... I will probably buy a new one on Amazon then look for another solution when my ATT contract is finished. Unfortunately we do not have DSL available in our rural location.
