RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
Rcmaling
Nov 29, 2015Tutor
I tried removing the sim, battery and factory reset...nothing worked. Also I tried using it without a battery installed but it would not start... I will probably buy a new one on Amazon then look for another solution when my ATT contract is finished. Unfortunately we do not have DSL available in our rural location.
cathyr
Dec 03, 2015Tutor
After going through two replacement batteries, two factory re-sets, removing the SIM card and battery the unit is now showing the No Battery error again. Each time, the battery has to be removed and replaced. Nothing has worked for more than a day or two. No one at ATT or NetGear has been able to fix it. They want us to buy another unit - no chance! With a year left on our contract all I can do is put up with it and not renew the contract. I'll never buy another NetGear product either. After seeing all the complaints here with the same exact problems I have no doubts that ATT knows about whatever this defect is but is still selling the units. Shameful. I'm done with this shoddy POS.
