RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
apac_se
Mar 02, 2015Apprentice
I would firstly try to perform a factory reset to see if the issue disappears. Failing that I would contact the returns area to organize a replacement battery. Maybe try another battery if you can find one. Possibly a carrier store.
JasonE
Jan 12, 2016Aspirant
Same issue for me also, and googling the problem it seems to be wide spread.. I went looking for a replacement device and my only option is another updated netgear product for my carrier.. I dont know if i want to risk it considering this is a known replicatable issues with this product.. does the new version have the same flaw?
I have tried everything, new battery pack , factory resets, pulling the sim ect.. even setting the screen time out to never go to sleep, same isues.. I tossed money at this with new batteries, and my carrier must also be loosing money on the data I could have been using with them with a properly working device... that I am not using now..
Netgear fix this product or make it right for your customers and restore faith in your company's products.
- cathyrJan 17, 2016Tutor
Hi Jason sorry you are having the same problems we had. There's no fix but to buy another device, and the AT&T store had one called the AT&T Velocity (not a NetGear product) that so far is working just fine. We paid about $100 out of pocket. No refund on the 770s, we were one year into our 2 year contract and the warranty ran out.
