RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
MadTechSkilz
Mar 16, 2016Aspirant
Just began experiencing the same issue on my Sprint NETGEAR AirCard 771S
I work in tech support for an unrelated business. I have read through this message board, and all the workarounds everyone has tried, and seeing how wide spread the issue is.
Problem
NETGEAR AirCard 771S reports "No Battery" and will not function
Model
Analysis:
1. How likely is it that so many batteries are going bad within such a short time frame? No very!
2. New battery... still issues
3. Factory reset... still issues
4. Reseat SIM card... still issues
Questions:
1. Has anyone checked the firmware version?
I believe that,perhaps, NETGEAR released a firmware upgrade that has a defect that is triggering the "No Battery" error on these devices. Since the firmware is automatically updated upon connection to the internet, and consumers are unable to block firmware upgrades (to the best of my knowledge), it points to the most likely reason for these issues.
If we all can share the firmware version of our problematic devices, we may be able to identify the faulty firmware versions. Then NETGEAR can, perhaps, release a new firmware version with a fix.
Model: AirCard 771S
Firmware Version: NTG9X15C_45.04.12.05
Firmware Build Date: 01/19/14
jor
Interesting theory, but not sure that's the problem. firmware versions both before and after factory reset are unfortunately the same for 770S:
Version NTG9X15C_01.18.02.00
Build date 09/30/14
side note, i have several of these for different devices located in different places and am now having the same issues with all of them.
