RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
Duckdad62
May 14, 2016Aspirant
I agree with this conclusion considering our position as end users. All the providers must know of the issue. Oddly my problem started about 3 weeks ago. All the symptoms as have been noted. My build date is 05/01/14 I just reset and same date. Why wouldn't it upgrade? I think there is firmware problem. Software check says no update. The fact that time of problem is so consistent and that when it works it's ok makes me think there's an unseen problem like maleware affecting download firm/software. Whatever there should be a resolution for this lemon. I do not know what agency could help. If any ideas on this I would be glad to support it. JL
- engdpMay 14, 2016Aspirant
Clearly this is a firmware upgrade that introduced a problem bigger than what was trying to be improved. Thirty years working for a company that did software updates a couple times a year ...I saw it far too often. Just as an FYI ... removing the battery and keeping it on the power cord has worked for me. Some mornings it has shut off and I need to unplug and re-plug it in again....so it has not been too much of an inconvenience. But it works for me.
