RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
Mary_Cooper
Jun 19, 2016Aspirant
I bought a certified refurbushed Untie in October 2014 and started getting the "No battery" message on June 1, 2016. When this happens, the Unite stops working. I have NOT tried replacing the battery, yet, but have just been removing and replacing the existing battery. It will then run for short periods before displaying the "No battery" message again.
I am also getting a software update failure message.
Firmware Version NTG9X15C_01.18.01.00
Firmware Build Date 05/01/14
When I go to http://attunite to manage the device, and go to Settings/Device/Software Reset and choose "Software Update" I get:
Update Error
There was a problem updating your device. Please try again later.
This is also displayed directly on the device's touchscreen.
