RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
Damon58
Oct 17, 2016Aspirant
Add my grouse to the covey. Twice. Replaced my modem last year for the same reason. Had to buy the same model 771S as Sprint said it was the only model my plan would work on. Sounded like BS to me, but hard to argue with a Gorilla .
Both units lasted almost exactly a year before the "No Battery" error starts popping up. Really torques my bolts.
Units work great when they work.
Error seems to pop up at the point where the battery is either full and calling to be disconnected or empty and asking to be plugged in.
Firmware version NTG9X15C_45.04.12.05
Build Date 01/19/14
