RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
JasonN
Mar 16, 2018NETGEAR Employee Retired
Hi fall,
I just wanted to check in on your and see what I said has helped you. Also is your device's firmware up-to-date- with the most current version?
Please let me know. :]
- Jason N
fall
Mar 17, 2018Initiate
Hi Jason. Yes, thank you for answering my question. I don't think my firmware would even update when I first turned on the hotspot. I think it said no updates were available. so I'm not sure if it's up to date, but it still seems to be working fine. Keeping the battery out but charged in case of an emergency.
