RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
apac_se
Mar 02, 2015Apprentice
I would firstly try to perform a factory reset to see if the issue disappears. Failing that I would contact the returns area to organize a replacement battery. Maybe try another battery if you can find one. Possibly a carrier store.
