RoSu54
Jan 01, 2015Follower
AirCard 770s no battery error
Intermittently my AirCard 770s displays a no battery error. Removing the battery resets the AirCard and the AirCard works ok for 15 minutes then displays the no battery error again. The battery is fu...
apac_se
Mar 19, 2015Apprentice
Hi All,
I am an employee of NETGEAR Australia. I would recommend getting your device replaced if factory reset or new battery does not resolve your issues. It sounds like a hardware issue.
- pskzfordAug 05, 2015Initiate
I was told that I would have to purchase a new device because mine was out of warranty and I was not eligible for an upgrade. I will not be renewing my service on this device in October. This is the second one to do this with me. Exact problems everyone else is saying.
- docsdockAug 24, 2015Tutor
Just started have the no bat error so i went to att and they did a factory reset and said it should be fine but if not go to an att store and bu a new one -- I have had it a little over a year - shouldn't it last longer that that ????
- VAMikeMar 16, 2016Aspirant
I can verify that doing a factory reset and installing a new battery will not resolve the "No Battery" condition on the AirCard 770s. I'm looking for a better unit. Any suggestions?
